Does anyone have any wiring diagrams of the bedroom area and rear clearance lights
#1 I was trying to diagnose why my clearance lights were non op, I was told to check in the cabinet above the bed. I opened it up and saw that there were a bunch of wires that looked like small silver cables, the factory left a piece of cut sheet metal exposed and apparently this caused some type of small sparks, when that happened I lost all the bedroom lights and radio power. I cannot seem to locate a fuse in either bay (one in front under driver and pass side near batteries) Anyone know where the fuse might be??
#2 I found the 20 amp fuse that powers the running lights in the bay under the driver, this fuse is "popping" Now it is interesting to me that once I found a loose ground mounting point right on the frame in front of the motor, that it was loose, I tried to move it so that it would get a good connection and pow now the #20 keeps popping. Any suggestions on this one? Could this be tied to the wiring in the bedroom cabinet?
Could someone please post a pdf of the house wiring for the bedroom and the rear clearance lights?
Much appreciated.
RUNDLC
