2003 Fleetwood Pace Arrow 36r
cjd10
Going with my brother-in-law to look at a 2003 Pace Arrow 36R today. We both are aware of the general things to check, roof, appliances, water leaks, tires, but was wondering if there was anything specific to this model we should pay particularly close attention to. He is a mechanic and very capable of checking engine and suspension and such. I have owned three MHs and can help with the interior of coach. Searching the forums I didn't find anything negative when it came to the Fleetwood models but thought I might ask the experts here before we go.
Clyde and Elaine
2014 Georgetown 351DS by Forest River
2 Boston Terriers 1 French Bulldog
Rest in Peace Toby
5 REPLIES 5
abrasv
Had an '03 for awhile. Great unit. One issue I found with mine was one of the rear spring hangers was cracked part way thru. Didn't even notice it until after putting a few thousand miles on it but it never caused an issue and then we fixed it. Just something you may want to check.
Jim and Carol
'05 Discovery 39S
'06 Dodge Dakota 4x4 quad cab
'37 chevy sedan
Bob___Ann
Check to see if the tires have been replaced. If not you will have to do so. Also you will need to consider the TVs as they will need to be updated to receive a signal today. Good luck with your decision.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
JaBob
Have a 2003 38B, great unit. Window condensation has never been a proble. About to retire the olde girl. Will miss her.
Bob
jwoodie
I was told to check windows for leaks/condensation.
Valkyriebush
That's a very good RV in my opinion. Seems like you got it covered though.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
