We could use some advice: We have a 2003 Winnebago Adventurer and can't get our levelers down. Therefore we can't open our LR slide as the RV sits crooked. We have asked everyone, including the Winnebago dealer where the box is for the levelers (so we can check the fuse) and each time we're told it's somewhere else. My husband can't find it anywhere and we hate to take it to Camping World for repair only to find out it's just a fuse. The levelers were working fine just the month before, and when we took it out again we couldn't get them down. The dash light signaling that the levelers are ready to descend doesn't come on and nothing happens. Does anyone at Good Sam know where the box containing the fuse for the levelers is? It's not under the stairs, in the other fuse box or behind the front driver's side wheel. We know where it's NOT! Anyone have any ideas?
Need more information. Is the control panel lighting up when you power it on? If so, what happens when you push the buttons.
Is your slide still operable or has that stopped working as well.
There are about 8 fuses for the entire system, 4 on the box itself above your left foot when sitting in the driver's seat. You have 2 more (working from memory here) on the wiring next to the pump in front of the radiator. The system also has a fuse on the fuseblock when you rotate the dash panel upwards, but it controls other things as well....the outside temperature guage is the item that won't be illuminated if the fuse is bad.
Let me know some more information as I got to know this very well last summer. I'm speaking of the HWH leveling system btw.
what kind of chassis? Our '04 adventurer on a workhorse has fuses under the dash. Flip up instrument panel. The light for the revelers won't come on until you set the parking brake, is that switch good?
