2006 Fleetwood Bounder 35E (Gas)
proaspen
Had the utility light on the other night, as well as the light in the utility compartment. When I was finished, I turned the compartment light off, and everything went dark, including the external utility light. I think I burned a fuse. Now I'm looking for the fuse panel. I think it is in the one to the left of the driver's seat. I popped off the panel and there are fuses there. However, no diagram. Anyone know which one controls the untility light? Or, do I have to do it the hard way and pull each fuse? Appreciate your assistance. PROASPEN
3 REPLIES 3
proaspen
Thanks! Turns out the fuse is in the battery control box located outside the rig in the same compartment as the propane tank. Fuse # F21
1492
Moderator
Moderator
Moved from Forum Technical Support
othertonka
Check the fuse panel in the bedroom. It is where the 110 V AC breakers are located but there is also a fuse panel for 12 V DC things in the same cabinet, might be location for what you are looking for
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
