Hello all,
My 2007 RT 210 Popular has a 1.6 Amp power draw that is draining my coach batteries.
I have the Tripp Lite inverter and it already has the remote cable and switch factory wired to turn it off. So, It is not causing the draw.
I have already hooked up my amp meter between the negative battery post and negative cable and that shows a constant draw of 1.6 Amps. After looking for lights mistakenly left on, etc., I tried pulling every fuse and shutting off every breaker one at a time to isolate the draw. No luck.
So, with my main battery switch off on the panel, still a draw.
Any idea's would be very helpful!
Jeff
