Apr-01-2016 06:05 AM
Apr-17-2016 07:38 AM
Stutch wrote:
I have a 2011 CRV that I tow. Spent $90 extra for a cut off switch when getting it prepared for towing. I use a Brake Buddy.
That said, the $90 was a waste of money. The radio fuse that the switch controls also cuts off the accessory jack. I had to rewire. I know you don't use a powered braking system but I went months without using the switch. I turned off the radio, made sure the fan was off and I would go 10+ hours with no issues.
My 2011 had very few miles on it when we bought it so I will assume the batt is "less used" than yours. Point is, go get a good battery and forget about everything else. Don't waste your time with a switch!
Apr-14-2016 05:34 PM
TropicalRV wrote:WILDEBILL308 wrote:
Effy, if you are going to have a long day towing I would start the car when you stop for lunch. I use to do this but now my long day is about 6 hours.
Bill
Starting the car and running it for a few minutes will suck more power out of it than the alternator will add. Even if you run it for an hour is not enough. If you have a newer battery and use an auxiliary brake, you may last a couple of days towing,
.My 2002 CRV has the least amount of phantom loads, but I carry a battery charger and charge the battery when overnighting in a campground.
Apr-14-2016 03:44 PM
Apr-14-2016 04:39 AM
Bill
Apr-10-2016 07:39 AM
Apr-10-2016 07:37 AM
Apr-08-2016 07:26 PM
Apr-08-2016 02:35 PM
GrampaR123 wrote:
Sam Spade, I keep telling them about the simplicity of the charge line and how easy it has made things for the towing of our CRV but for some reason everyone thinks it involves "breaking into your electrical system". Nothing could be further than the truth. A simple fused line run through your harness and connected to your car battery is all it takes. Simple!! It's good to know there's at least one other person out there that understands.
Apr-08-2016 02:31 PM
Apr-08-2016 02:15 PM
Apr-08-2016 06:05 AM
Wrong Lane wrote:
I guess I will have to add more panels for more charging capacity!
Apr-07-2016 04:54 PM
Apr-07-2016 09:47 AM
Apr-06-2016 06:00 PM
