2013-2014 Excursion
mike_brez
Looking a the 35b. Would like to hear the good and bad for any of the Excursion models.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
5 REPLIES 5
mike_brez
gone2dadesert wrote:
et2 wrote:
Is the Excursion that much cheaper than the Expedition? Maybe with a little more pressure on the dealer you could make it work. When we looked they were about $20,000 difference from each other. I see there weren't any responses, but I've heard many people enjoy their Excursions.
Based on the two links below, I noticed a difference with motors and number of slides. However, I'm sure there are more differences to justify the price disparity. Personally, I'd like the Expedition between the two choices.
Excursion 35B
EXPEDITION 36M
I think that 35b is the same one I looked at last week at LaMesa in Fla.
2015 Wrangler JKU
Valkyriebush
The New Excursion is a different version of the previous Excursion. Which was replaced by the Providence. The new Excursion is shorter and has a smaller engine/tranny. The Expedition was one model below the previous Excursion in Fltwds line up at one time. I like it if your looking for a smaller pusher. Not sure where they are positioned compared to each other now. The Expedition has good history. The New Excursion does not. (History) All the new FLTWD DP are much more upgraded then previous iterations. Even at the entry level.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
gone2dadesert
Excursion 35B
EXPEDITION 36M
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
mike_brez
et2 wrote:
Can't speak for the Excursion, but we just purchased a 2013 Expedition. Really like it. Our first DP. For the most part it has been the most trouble free RV we have purchased new.
Two things come to mind, check your tire pressures and inflate (tire mfg rec) based on the actual weight of your coach. It makes a big difference on how it drives. Second check the house battery levels immediately, mine were low from the dealer/factory.
Just quick looking and asking around about 140k I haven't crossed off my list a older higher end DP
2015 Wrangler JKU
et2
