2015 Thor Hurricane
Mike2422
I got a 2015 Thor Hurricane and furnace keeps blowing 15amp fuse. Fuse blows as soon as i try to turn furnace on. Took covers of furnace no visible shorts in wires when I unplug furnace from rv connection and try to turn it on its doesn't blow fuse any ideas what's wrong bad board in furnace or what can I check next. Thanks in advance
4 REPLIES 4
Mike2422
Will do thanks
bullydogs1
isolate problem to furnace itself...find 12 v wire going in and make sure it gets 12v from thermostat...Almost bet it could be fan motor itself..or a grounding connection on the furnace...
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
Mike2422
I have done that seems to spin freely any other ideas.
wolfe10
Try to spin the fan by hand (yes, with furnace OFF).
Could be that a mud dubber nest is keeping the fan from spinning properly, causing high amp draw.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
