Mar-20-2016 07:37 PM
Mar-22-2016 10:07 AM
Gjac wrote:Bruce Brown wrote:Do you think you would really notice 3 more ft-lbs of torque?wildtoad wrote:
Of course the net of all this is that if you are going to buy most any 2016 gas motorhome you are going to get the new engine and transmission. I just bought a 2016 Newmar and it runs just fine. I have read some posts about the downshift with some saying it works well, others say not. Have not been a situation yet to know.
I wonder how much of that is in the operations side. I know on my Super Duty diesel (same transmission, I believe) if you do nothing it doesn't hold much back, if you tap the brake once to let it know you want it hold back it does a wonderful job of doing so.
You are also correct on if you buy a gasser today thats what you're going to get - Ford is the only one left in the gasser game as far as I know.Gooding. R wrote:
The HP takes it down the road and the torque climbs the hills without changing gears. The latter is the most important. You can move an RV with a 10 HP motor but it has no power without the torque.
Exactly. HP is good for bragging rights, torque is what gets the job done.
Mar-22-2016 09:35 AM
Mar-22-2016 04:05 AM
Mar-21-2016 04:57 PM
timmac wrote:. You are already way ahead of the game. With 400 HP in a 32 ft MH there is not many Gas or Diesel MH 's that will pass you on a hill.Gjac wrote:timmac wrote:Does your Banks power system include headers? How much more HP does your Banks add? How much more HP does your 5 star tuning add? Sounds like you are already ahead of the game.smkettner wrote:
With more torque I doubt you will notice. How often do you really run 4750 rpm for extended periods?
Power curve is just a bit lower on the chart.
Lots of people seem to think a little lower RPM might be OK.
Its 42 less HP through out the curve, just not at 4750 RPM's, and the new one only has 3 more lbs of Torque if that is correct, maybe they just added the 3 lbs to make people not notice the 42 less HP, Gas motorhomes don't have lots of extra power like diesel so why have less power, I thought the HP was to go up not down, its not like the motorhomes are getting lighter.
And yes its the same ratio in 6 gear as the 5 speed trans is in 5th gear..
I will keep my 42 HP, Banks Power System and 5 star tuning and pass the new 2016's while towing going up the mountains..
Cant say for sure but conservently I would say I have 400 HP and 500 lbs of Torque but Banks rates it higher, and yes I have the Banks headers.
Mar-21-2016 02:03 PM
Mar-21-2016 01:38 PM
Mar-21-2016 01:04 PM
Mar-21-2016 12:58 PM
Mar-21-2016 12:46 PM
Mar-21-2016 07:58 AM
Mar-21-2016 05:34 AM
Mar-21-2016 04:33 AM
timmac wrote:Kayteg1 wrote:
I notice the lower HP engine also has higher torque at lower rpm, meaning theoretically should pull better in RV application.
That if it is coming with properly selected gears.
But at 3250 RPM's the older V-10 has 357 lbs, 3 lbs is not to much difference.
But 42 HP is a lot.
Mar-21-2016 03:13 AM
Mar-21-2016 12:21 AM
