If it was on E-Series, Ford would want at least 33% of total weight on front axle, and you have nearly 39%. This is GOOD! As you add weight for travel and camping, try to make sure 1/3 - 1/2 of that addition is forward of the rear axle. In other words, try to keep that upper-30's%. Your passenger's weight will help. Then weigh again, and this time use a weight-to-pressure chart to set your tire pressures. You're well on your way to a good ride!
