May-08-2019 05:59 AM
May-14-2019 10:32 AM
May-09-2019 04:30 PM
May-09-2019 02:01 PM
rogerddd wrote:Thanks for the report Roger, are you now looking for a larger MH? Had you looked at other 24 ft MH's before buying the 4 Winds?
Gjac, We have a 2018 Thor 4 Winds 24FS - bed and living area slides on the driver’s side. It is our first motor home and I think we learned a lot.
Overall was it a good decision? It was a good learning decision. We traded a 5th wheel camper and felt good about the exchange. We are now shopping for another motor home (not Thor) with some of the features we missed in the one we have. Thor, probably like all manufactures, delivered an RV initially needing multiple warranty work repairs. The micro is low so it is not as easy to access as I would like. The access to the toilet with the slide in requires moving the slide out some. We have a Girard instant hot water heater (DW hates it). Hooked up to city water with a pressure regulator it almost works. Dry camping – not to good (hot and cold, hot and cold, etc.)
I like the roomy living space, rotating driver and passenger seats, open overhead area which we use for storage, adequate inside cabinet storage, access to the bed with the slide extended and it has a comfortable bed (we use an added mattress topper)
Storage? Outside storage compartments are very good, some are big enough to store plenty
Models with large storage areas? I don’t know.
Ride quality? We have a Mercedes chassis (diesel) and it is very easy to drive and comfortable to ride in.
May-09-2019 01:56 PM
bobndot wrote:Yes , that is the pass through storage bay I was referring to, although much bigger that the ones I have seen on small Class C's and A's. I never saw this RBT model before, too bad it didn't have a slide.Do you know which makes have those?
I'm sorry, no. Are you looking for full pass thru storage tall enough for bikes ? I do remember seeing some units with compartments like that.
If that's the case, I will try to retrace my steps and shake my brain. Hopefully something will stir my memory .
I did save a lot of stuff when I was looking for my unit. I guess you can call me an RV research hoarder. :B
I was thinking of the Leisure Travel van 'Wonder RTB model. Its a small class c or B plus, however you want to classify it. Rear twin bed model has the bike storage. However if you are in the 'more room slide mode', the Wonder would be too small for you.
May-09-2019 11:02 AM
May-09-2019 06:12 AM
Gjac wrote:way2roll wrote:I think just about all the newer MHs use these slides now at least the ones I have seen. A slide on a 24 ft C would be a lot smaller than on a larger A where you here about these problems. The slide system on my 1996 GBM MH is HWH and I never had a problem with it. I can crank it out in in with a hand crank but never had to use it.
Thor and a few others use Schwintek slides. Originally these full wall slides were prone to failure. The slide mechanisms were too weak. The answer to this solution was adding a 3rd rail at the top. While I haven't heard of any more failures since this "fix" I vowed never to own an RV with a full wall slide using the schwintek mechanisms. You may never have an issue but do some homework on the types of slides used. I think Winnie stopped using them for that very reason. My $.02.
May-08-2019 04:40 PM
May-08-2019 11:11 AM
May-08-2019 11:03 AM
May-08-2019 07:22 AM
May-08-2019 06:22 AM
