30 amp to 50amp Adapter
David0725
Can a camper with 30amp plug in to 50amp service with a adapter? what would happen? Its still only receiving 120volt right? or No.
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
22 REPLIES 22
jhilley
1BryNelson wrote:
I bought 1 of those digial voltmeters; very interesting to watch what appliances take what voltage, especially at start up.
I think you mean current (amps) at startup.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
1BryNelson
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
tropical36
Larryr wrote:
In reviewing the response from RoyB note that the 50A service is 240 single phase AC with two hot legs at 180 degree opposite phase .at the 30 A end (see his sketch ) only one of the hot phases is connected ( 120v and neutral ). Accordingly, only the breakers in the RV Load Center connected to that phase can be operated. Breakers in the Load Center connected to the other phase bus bar are thus not powered and their connected loads will not receive power per the sketch.
Look again. The 50 is the male and the 30 is the female. The 30 male mate for it has a breaker box with all the breakers connected to this one hot leg.
If it were the opposite like you're thinking, then there would be a jumper across the hot legs of the 50amp female and thereby providing power to both legs in the box, even though of the same potential and limiting usable power to 50%.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Larryr
tropical36
jhilley wrote:
It's no different than plugging an 18 gauge extension cord into a 20 amp receptacle. It is after all an extension cord and not directly wired.
I agree and the only thing with extension cords per say, is that they're supposed to be completely visible and not hidden behind walls and such. A rule that's not always followed and other misuses have caused a few fires, I'm sure.
Again, I'm totally in agreement with the theory here, otherwise I would have never put a 50amp plug on my 30amp cord to begin with.
Even though unrelated, I also installed a dual power adapter of sorts, using a 20amp plug and outlet for splitting the rear A/C circuit. This enables me to plug into a separate pedestal outlet for the rear air, thus taking some load off of the main shore service.
This in effect does the same thing as running the coach with the gen set and the way it's automatically setup for doing this same thing, since the generator is capable of at least 45amps and has it's own 20amp breaker for the rear air conditioner.
jhilley
tropical36
holstein13 wrote:
tropical36 wrote:
Yes, I thought so and really like using it much better. Some will nitpick about the 50amp breaker for protecting the smaller cord to the interior's main, but no different than using one of those dog bone 50/30amp conversion cords like the OP is talking about and pretty far fetched for it to ever cause a problem when you get right down to thinking about it clear through.
Just have to be sure and wire it right, so as not to supply 240vac to a 120vac coach.
This is a great idea and should be no risk at all. You will only draw 30 amps maximum anyway because your entire coach is protected by a 30 amp breaker so you are just fine. Your cord will suffer no ill effects at all. It's not as if 50 amps is pulsing through there and being limited by the breaker on your coach.
But please don't share your idea with too many folks. I have to use 50 amp on my coach and I don't want everyone wearing out our nice tight functioning outlets at the campgrounds.
Only thing is, it's a matter of proper procedure and with just #10awg wiring between the 50amp pedestal breaker (should be 30amp) and the rig's main 30amp breaker, it not properly protected. Now having said that, a direct short between these two points will trip the 50amp instantaneously and it's pretty far fetched to have a situation where there could be a steady overload above 30amps between these two points. Like I said, it's no different than using a 50/30 conversion cord and evidently UL approved, so.....
holstein13
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
David0725
@ frankdamp Its not about getting more power to the rv its so if your running the A/C and micro. at the same time we don't blow a backer. both only give you 120volts but the 50amp can hold the load better then the 30amp.
frankdamp
Your RV draws the amount of current it was designed for. If it's a 30A rig, that's its limit. If you're plugged into a 50A outlet through an adapter, the rig is still limited to 30A of service by its internal system limitations.
Consider voltage as "electrical pressure". If your system is limited to a certain flow rate (amps) because it was designed to work on 30 Amps, that's all it will consume. The "pressure" is not an issue. It can't force more electricity into your rig than it can consume.
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
tropical36
jhilley wrote:
tropical36 wrote:
The OP's question has been answered.
Now, I went a step further and put a 50amp plug on my 30amp service. Now use a 30/50 for when a 50 isn't available. Got tired of all the cooking with the 30amp plug and having new ones ruined with loose and burned campground outlets. So far we haven't had to use the converter cord all that much and it has remained in good condition with the 50amp plug itself, in like new condition.
First time I've heard of anyone doing that, but it is an excellent solution. Gives you a much heavier plug that won't over heat.
DennisVR
I have a 40' toyhauler with 50amp service. I use a 50a to 30a adapter at the trailer and use a 30a cord. I have a 30a to 50a adapter also in case I want to hook to a 50a service. I leave my heavy a$$ 50a cord at home. I would only need it to run both ACs and if it gets that hot its time to move.
jhilley
RoyB
This is a 30AMP FEMALE to 50AMP MALE ADAPTER diagram by DMBRUSS showing that only ONE HOT leg of the 120VAC 50AMP service is being used.
We also carry one of these adapters with us to use. Alot of times the campground 30AMP PEDESTAL SERVICE is worn and showing burn marks which we DO NOT want to plug into.
A great PLAN B to have with you.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
