โFeb-06-2014 01:05 PM
โFeb-15-2014 05:53 AM
BillMFl wrote:
You are hard to please. haha I could have said the Eco boost engines are more fuel efficient because they have turbos (some have 2) that squeeze more horsepower out of a smaller displacement engine thus using less fuel while providing good performance. But the key point is that it is the turbo that allows the Eco boost engines to be more fuel efficient while still providing enough HP for good performance. A small engine without a turbo is even more fuel efficient but a dog to drive unless the size/weight of the vehicle is reduced. Lots of variables to consider. Wanna throw in wind resistance/air flow? We can beat this to death!
โFeb-14-2014 07:53 PM
โFeb-14-2014 05:44 PM
โFeb-14-2014 05:40 PM
โFeb-14-2014 05:08 PM
โFeb-14-2014 04:52 PM
โFeb-14-2014 11:29 AM
Daveinet wrote:JumboJet wrote:On flat land, it only takes 420 HP. I've seen 98 3 times, 2 of those times it was towing the same Jeep. It had plenty left, just ran out of open countryside. Lower profile helps on wind resistance.
You can build a 900HP 360 c.i. engine that will push that 18,000 lb. motorhome over 100 mph, but it will not last very long.
But none of that matters, what really matters is what is practical to drive. One should note that the stock Workhorse gas chassis has a 30,000 GCWR.
โFeb-14-2014 09:23 AM
โFeb-14-2014 07:27 AM
JumboJet wrote:hardtobe wrote:
There are only a few 500 mile Nascar races these days and one 600 mile one and its not because of engines.its more with TV,fans, etc etc
If race is too long you loose your viewing audience etc
and besides what does it have to do with gas verses diesel??
I have seen many NASCAR engines fail in those races. It did seem there were less engine failures last year though. Mostly broken valve springs.
โFeb-14-2014 07:08 AM
โFeb-14-2014 04:40 AM
โFeb-13-2014 06:56 PM
BillMFl wrote:Sort of. Technically the turbo does not increase efficiency, but just allows the use of a smaller engine, which is where the efficiency lies - allows it, because it increases HP.
Ya I know, but I don't know of any rv gassers with a turbo. And not many diesels out there without a turbo. Interestingly the new "Eco boost" fuel efficient engines in passenger cars are using turbos to squeeze more efficiency out of less fuel. Used to be that turbos in gas engines were mostly used for more horsepower in high performance cars.
โFeb-13-2014 04:34 PM
OhhWell wrote:BillMFl wrote:
The diesel also does much better at high altitude than a gas engine, but many rvs seldom make it to the Rockies.
That's the Turbo again, not the fuel type.
โFeb-13-2014 02:09 PM
wny_pat wrote:
Original question in this thread:RMIGHTY1 wrote:
OK, newbie here and aspiring RV'er. What comments can be made about the advantages/disadvantages of a 350 HP internal combustion engine vs. a 350 HP diesel engine in a class A camper (assuming all other variables are equal)?
Good first post which certainly opened Pandora's Box. If you intend on putting on a awfully lot of miles and keeping the rig a very long time, you want a diesel pusher. If you are not going to put mega miles on it and don't plan on keeping it for a long time, you want a gasoline rig. And if you have read all the posts in this thread, you probably now realize that not all 350 HP internal combustion engines are not created the same, and the same with 350 HP diesel engines.
