Jun-06-2019 10:05 AM
Jun-08-2019 11:05 AM
wa8yxm wrote:Yes of course. Both NEMA 5-30 and 30-TT read the same.
Time Roll did you read the face of that outlet you posted
30 amps 125 Volts.
As I said up thread. Many electricians do not read.
Jun-08-2019 05:14 AM
Jun-08-2019 05:00 AM
Jun-07-2019 07:54 PM
Jun-07-2019 02:37 AM
Jun-06-2019 07:08 PM
CA Traveler wrote:NEMA resisted recognizing the 30-TT for a long time and I assume partially for this reason of similarity. Besides NEMA already had a 5-30 connector that is not confusing.
It's unfortunate IMHO that a unique 120V 30A RV plug that is almost identical to the common 3 wire 240V dryer plug was used for RVs.
Jun-06-2019 06:47 PM
Timothy2001 wrote:Executive wrote:
Whoa Kimo Sabbe! It's a bit more complicated than simply replacing a breaker and receptacle. That is unless your home fire insurance is paid in full, you no longer like your house, and the insurance company won't find you at fault for frying all the wiring inside your box. Generally, 20amp service, (Tee shaped receptacle) uses 12 ga wire, 15amp service (Double I shaped receptacle) uses 14 ga wire. 50amp service uses a minimum of 10ga wire, depending on the length of the run. Simply changing out the breaker and receptacle will allow you to power up you A/C units for a bit as your breaker will not trip. However, your house wiring will then become a substitute for your breaker. Once the wiring gets too hot, it will melt and burn through if you're lucky. If you're not so lucky, it'll simply start a fire and burn your house down. Hire a licensed electrician....Dennis
LOVE THIS! I learned a long time ago what I am capable of, what I am not capable of and what is just plain stupid to attempt and this falls under the later.
Anyone who was in the Navy remembers, "The Deadly Shipmate" and I prefer not to mess with electricity at sea or on land unless it's a simple light switch or house outlet.
Jun-06-2019 06:14 PM
Timothy2001 wrote:mtofell1 wrote:
Getting a full electrical service at home is a really nice thing to do/have done. I love being able to use my RV to the fullest even in the driveway (hell, even the "doghouse" isn't so bad when DW sends me there :))
Next step is to be able to dump tanks at home. This was a real game changer for me. No more waiting in line heading out of the campground on Sunday. No more making the kids "hold it" until we get home.
So is this a 'hostile integration' into the plumbing that goes out to the street assuming city sewage and not septic?
Very appealing to me too.
Jun-06-2019 05:58 PM
dalenoel wrote:X2wa8yxm wrote:
Final note.. I know the TT-30 (30 amp) Outlet looks a lot like a 240 volt Big, Black, Large blades. MANY Electricians hired to install one will think that too.
And blow all your electronics
It is 120 volt. Says so right on the outlet.
Had a friend just get this done by a licensed electrician and is now having the RV, brand new, fixed since it was 240V and not 120V. Question the electrician as to what he is installling and then double check with your own VOM.
Jun-06-2019 05:43 PM
BB_TX wrote:
I can run one 15k A/C on a 20 amp outlet as long as I run nothing else. But I would not do it on a long extension cord. On 30 amp you can easily run a 15k A/C plus a few other lower current things. On 50 amp you can run all you want.
Make sure whoever installs the new outlet understand how it should be done.
http://www.myrv.us/electric/
Jun-06-2019 04:35 PM
Jun-06-2019 03:59 PM
Jun-06-2019 03:52 PM
Jun-06-2019 02:38 PM
