โJan-05-2014 12:54 PM
โJan-25-2014 07:16 AM
FRED555 wrote:ronfisherman wrote:
The dark blue wire is correct wire for output to trailer brakes. Light blue wire is to activate the brake controller. Hooking to the brake pedal switch will cause it to fail. You will find many threads on the internet about chimes going off in MDT's and how to fix it.
If we have to use the light blue wire in the harness on the frame rail where do I find it in the cab? It must somehow get to the fuse panel and eventually to the same wire from the brake pedal?
Very Frustrated.
Thanks,
โJan-25-2014 07:01 AM
โJan-25-2014 06:50 AM
โJan-25-2014 06:19 AM
โJan-25-2014 06:14 AM
โJan-25-2014 06:09 AM
โJan-25-2014 04:16 AM
โJan-19-2014 12:19 PM
ronfisherman wrote:FRED555 wrote:
Also anyone found any place to get OEM or even non OEM carper and floor mats for cab?
Checkout mats for a Savanna/Express Van.
โJan-19-2014 11:48 AM
โJan-19-2014 11:45 AM
FRED555 wrote:
Took apart the plastic switch on brake light and emery clothes three contactors inside. This fixed the brake light and the annoying rattle when stepping on brakes.
Can anyone described the exact location of the other part that lights idiot light below radio? I cannot seem to find it. Also what is the idiot light supposed to warning of?
Went to take RV to storage and and stalled out a light. Would not restart. Beware the Duramax MUST have frequent fuel filter changes. Fuel filter cost $30 tow out of middle of road cost $100. I for one will do every oil change now.
โJan-19-2014 10:56 AM
โJan-19-2014 10:54 AM
โJan-06-2014 09:39 AM
โJan-06-2014 09:37 AM
