99 Monico Windsor and Silverleaf VMSPC
snickster
I have a new to me 99 Monaco Windsor that I would like to connect a Silverleaf VMSPC that I have been using on a 98 HR Endeavor.
The Windsor has the Cummins 8.3 L Engine with the Allison engine and the
Endeavor has the Cummins 5.9L ISB.
Is the VMSPC able to connect and work with the Windsor. I don't see any connector that will match the VMSPC Hardware connector.
Heading for the Rockies soon , and I would sure like to be able to have
all the data available that the VMSPC provides while climbing those grades. ( Especially on an unfamiliar coach !)
Thanks
The snickster
Mark and Priscilla
98 HR ENDEAVOR 37 WDS Diesel
Jeep Wrangler Toad
THE YORKIES : Winston , Abby, Izzy
3 REPLIES 3
wolfe10
BTW, the 8.3 is the Cummins C not L.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
bluwtr49
I second calling Siverleaf, they are great to work with.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
Gary_
You could call SilverLeaf Electronics at 888-741-0259, or you could hook it up and go to the Advanced menu and under Engine Type select the correct engine. Not all engines support all potential gauge items. If a particular gauge always reads zero, your engine simply does not support that feature. Good Luck. Gary Maybe I'm not addressing your hardware question, but it seems to me if you had it hooked up to a Cummins engine before it should take the same hardware!
