Jun-12-2016 09:05 AM
Jun-14-2016 12:14 PM
keramiller1980 wrote:
dougrainer, thanks again. Zone 2 is listed, it just didn't show any functions. There has been no work done on the A/Cs. I wasn't able to get up on top but did go ahead and go through the reset procedures you provided. I did get the FF indicator. Once completed it now shows only "AGS Mode" and I can toggle on or off. I believe this to be part of the Automatic Generator Start feature which I don't need at this time. It doesn't permit me any other function options on Zone 2 however, just the AGS Mode. Zones 1 and 3 are still working fine.
Jun-14-2016 12:12 PM
bigbro36 wrote:
I have 3 zone system as well. Zone 1 and 3 operate off of shore power and zone 2 operates off my generator. I don't know if it can be changed, never tried as 2 units cool my coach just fine. My generator will operate all ac zones if required. 2007 Gulfstream Tourmaster
Jun-14-2016 11:23 AM
Jun-14-2016 05:17 AM
Jun-13-2016 08:09 AM
I have three roof top units and three zones indicated on my thermostat. My forward and rear units (Zones 1 and 3) work fine. On my thermostat, when I select zone 2 there is nothing to set, it's a blank screen. I was told a couple years ago that this was because it tags off the zone 1 unit. I don't think that was a proper answer and was asking this forum if anyone has any ideas. In short, I can't operate the center unit. Thank you in advance.
Jun-13-2016 07:28 AM
dougrainer, I thought the forum picked up my RV stats from the profile. Mine is a 2008 Holiday Rambler Scepter 42PDQ with Dometic. I believe that 1 is Forward (which is working), Zone 3 is the bedroom area (which is also working) and Zone 2 is for the bath and hallway area (which is the one not showing up on the thermostat.
Jun-13-2016 07:04 AM
Jun-12-2016 09:55 AM
Jun-12-2016 09:42 AM
Jun-12-2016 09:26 AM
Jun-12-2016 09:10 AM
