AC control panel malfunction
balfre1946
We have a RV Comfort ZC Control panel for our AC/Heat for our Class A 2010 Fleetwood Fiesta that has suddenly malfunction. We have two zones..1 and 2. When pressed, zone 1 no longer appears, zone 2 does and a non-existent zone 3 does with "Malfuct." Any idea why or what to do? Is it just a resetting or is the panel broken?
5 REPLIES 5
balfre1946
Doug, thanks...we will try it. BTW we stayed at an RV park in Carrollton just north of Dallas, first dent on our new RV was trying to pull in to one of their spots LOL!
Mandalay_Parr
Might look on the internet for a reset procedure. On mine, which is a different brand, you hold down two buttons while turning it on.
Jerry
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
balfre1946
I have no idea how to reset...shut off all power, didn't work.
dougrainer
Take the tstat cover off and remove the glass fuse for 5 minutes. Reinstall the fuse. That does a reset. IF that does not work, you have a wiring problem. Doug
Mandalay_Parr
I would try a reset first.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
