AC Thermostat Quit
Two_Hands
I have an RV comfort.zc thermostat in my coach (described below). It controls the front and rear air conditioners and the front and rear furnaces. Zone 2 is for the rear and it works properly. The thermostat will not change to zone 1 so I can't operate the front ac or furnace. I repeatedly press the zone button, but it stays on zone 2. I've done a search, but can't find anything. Can anyone offer any suggestions? Thanks in advance.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
7 REPLIES 7
dougrainer
Two Hands wrote:
Tinstar I thank you! I turned off the batteries, waited awhile and when I turned them back on the thermostat worked properly. I hope it is not just a temporary fix. Thanks everyone for taking time to read my post and reply.
The power down fix is usually for when the ZC control shows OO on the display. Never heard of it failing for just 1 zone not showing up and rebooting the power restored it. Doug
Two_Hands
dougrainer
OK, on the newer ZC tstats, they use a twisted stranded wire to prevent RF or AC Ripple interference. You can rule out this by having EVERYTHING OFF in the RV and then trying the Tstat. IF you have NO Zone 1 indicated and you had Zone 1 before. You need to go to the front Zone 1 AC and access the Control PC module. Open the cover and you should see a solid or flashing Green LED light. IF NOT, then there is no 12 volt power to that Zone 1 module board. You then need to verify 12 volt power to the module. IF no 12 volts on the 12 volt input, your problem is downstream either at the fuse block or possibly the Front Furnace. Some RV's use the Furnace power for the Power to the AC that is controlled at that Zone. It is uploaded by the 2 Furnace tstat wires from the furnace. One wire is 12 volts and the other is the return 12 volts when furnace heat is called for. Doug
doc_brown
My thermostat acted up and after some experimenting I determined it was a faulty ceiling light ballast. Removed them all and went to direct wired led's.
Steve,Kathy and Josh
Morpheus(Basenji)at Rainbow Bridge
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2014 Jeep Wrangler Unlimited Sport S, Air Force One Braking, Blue Ox
crasster
Have you looked on the front of each furnace for a furnace control board? It may be more involved than a thermostat. Sometimes control boards go bad.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
dturm
Moderator
Moderator
Just had the same thing happen. After troubleshooting, pulling fuses and trying the reset, I found the problem was the cell phone signal booster. As soon as I turned it off, the thermostat worked perfectly. Look for a source of RF interference.
Doug
Doug & Sandy
Kaylee
Winnie 6 1/2 year old golden
2008 Southwind 2009 Honda CRV
Tinstar
For a temporary fix, I understand you can turn off the house batteries for about 5 minutes and that will reset the thermostat. I've also read you can pull the fuse in the thermostat and leave it unplugged for 5 minutes to do the same thing.
If you search the internet for RV comfort zc thermostat, you'll probably find several post about this procedure and what causes the problem. Several sites says it's an electronic interference that can be caused by fluorescent light ballast, phone chargers, vent fans, etc. They say to put in a choke filter.
:CNever pass up a chance to go somewhere:C
