Air brakes on Class A diesel pusher
flyboykuao
Hello, we recently purchased a Fleetwood diesel pusher. We have been on 3 short trips with it. It is equipped with air brakes - when switched on the RV will slow when my foot is off the pedal. I read up, and now understand, how they work. What I am not clear on is WHEN to use them. I assume one scenario is when on a steep downgrade. What about using them during normal travel as a way to save the brakes?
I am interested in your recommendations. Thanks in advance.
22 REPLIES 22
Tom_Barb
The way I read this is, you don't turn airbrakes on or off, so you must be talking a engine retarder, there are several types depending upon the engine manufacturer.
I turn mine on when I need it.
azdryheat
I'd be reading the owner's manual.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
romore
The air brakes cannot be switched on and off, you are operating the engine retarder. Here air brake training and an endorsement are required even for non commercial vehicles, Oregon may do the same. Check with the dmv, you really need to be familiar with the system.
wa8yxm
Air brakes work when you press the pedal. Just like Hydraulics but with a few differences I won't bother go into (For more info see if your state publishes a book with a title something like "What Every Commercical Driver Must Know" I have a copy. handy reference book.
You are describing exhaust brake. Some areas do not allow but as someone else said. other than nasty road.. Use 'em.
Bill_Satellite
It could be an exhaust brake or a Jake brake but these devices have nothing at all to do with your air brakes. I would leave either brake on at all times during normal driving conditions as it will help you stop faster should that be necessary and it will save your brakes while headed downhill by using the engine braking power to slow you down.
Can't we all just get along?
Big_Katuna
I rarely use me foot brake except at traffic lights, very slow traffic. I coast a lot. so dont leave my exhaust brake on all the time but switch it on when I want to slow down. A gentle tap of the brake will force a downshift which will slow things down in a hurry.
My Kharma ran over my Dogma.
Mandalay_Parr
My exhaust brake is ON all the time except on Icey roads.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
dalenoel
It sound like you are not talking about the air brakes but about an exhaust brake. One that blocks the exhaust and thus slowing the coach. This will not stop you but will slow you down.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
