May-01-2017 04:27 AM
May-08-2017 11:36 AM
dougrainer wrote:
Page 11. Doug
http://bryantrv.com/docs2/docs/cccir.pdf
May-08-2017 10:16 AM
May-08-2017 09:27 AM
May-08-2017 04:05 AM
mchero wrote:
That clip looks like it should clip to a copper pipe on the evaporator coil, not push into the fins.
Perhaps Doug can chime in here with his thoughts.
May-07-2017 07:41 AM
May-07-2017 07:21 AM
May-07-2017 06:00 AM
May-07-2017 05:37 AM
May-03-2017 04:59 AM
vjstangelo wrote:
Sorry, I should clarify my comment. My current RV is a Winnie, the prior was a TT with a Coleman Mach 13.5 AC with controls on the unit. For that unit, the temp controller was a dial on the AC which sets the point at which the compressor will cycle off. This type of unit uses a probe (or thermocouple) that senses the evaporator coil dry bulb temperature. If the dial is set too low, the evaporator coil will get to a temperature below 32F hence the coil will build up ice. If that happens, the airflow will diminish as ice builds up on the evaporator coil fins.
I am in agreement with Effy in that a 13.5 BTUH unit will theoretically generate 13.5 BTU of cooling when the compressor is activated. The wall thermostat, or cooling temperature dial on panel mounted unit only turns the compressor on and off.
The danger of running the unit (compressor energized) with an iced over evaporator coil is that this could allow liquid refrigerant to pass from the evaporator to the compressor through the suction side hose/pipe and destroy the compressor (which is only designed to compress gas, not liquid which is incompressible).
To the OP, if the unit is no longer cooling the compressor could be toast due to liquid getting into the suction line when the coil was frozen and the compressor running.
May-02-2017 07:39 PM
damntough wrote:
Our Newmar had the exact same problem. Turns out the front unit was previously replaced. The new unit was installed without the foam gasket that separates the return air from the conditioned air. Most of the air just kept recirculating through the unit without ever going into the coach. I hope this helps.
May-02-2017 06:28 PM
May-02-2017 07:26 AM
May-02-2017 07:22 AM
May-02-2017 05:53 AM
dougrainer wrote:vjstangelo wrote:10forty2 wrote:Effy wrote:
Is it low on Freon? Why did you set to 64? Did you really want the temp to reach 64? Because turning it down further than the desired temp does not make it work any harder or faster. A thermostat is not an accelerator. If you want 72, setting it to 64 won't make it cool to 72 any faster than actually setting it to 72. It does not run cooler the lower you set it. If it froze up then it's low on Freon (or whatever they put in them these days). Were you plugged in shore power and getting the right power to it? Is the unit clean? If it can't breathe right it can't cool efficiently.
I set it to 64 because I like it cold in my RV and I wanted icicles hanging when I came back in from the hot concert....:B
I do know that it doesn't cool faster set that low, but it never seems to be cool enough inside until I get the temp (according to the thermostat) down into the 60s. All window shades closed and a floor fan running. I keep my house at 68 and ceiling fans running all the time..... I haven't had a problem in the past three years with the A/C units, but this time it just wasn't moving the air.
When I was up on the roof cleaning it, although I didn't remove the cover, I did visually look for tree debris and anything else I could see through the gills. All appeard to be good from the outside.
Effy is absolutely right. I can speak from experience as my DW once did the same on our 13.5 BTU unit. It was going to be over 100F one day in Denver and she set the tstat to very low temp. Since the compressor was not able to cycle off and defrost, the evaporator iced up even though the temp was hot outside with almost no cooling airflow coming out of the duct
I raised the temp so that the compressor cycled off and the evaporator ice melted. Told her not to lower less than 70F and no more problems.
Absolute rubbish. From your sig, you have a Winne. Wall Tstat RV AC Units have a FREEZE THERMISTER, which will NOT allow the evap to freeze regardless of anything else. IF your evap indeed iced up, you have a operational problem with the Freeze Thermister. FIX your problems. Don't post that some things are normal because YOU experienced a similar result. Doug
