Jan-08-2014 11:48 AM
Sep-09-2014 02:03 PM
Sep-09-2014 05:01 AM
Jan-10-2014 09:21 AM
Dale.Traveling wrote:
Something else to check is the fuel line from the chassis gas tank to the generator. If the line is or has rubber tubing there is the possibility of a potential leak if the tubing is getting old. It won't drip gasoline since the fuel pump is at the generator pulling gas from the tank but will suck air and limit how much fuel the generator is getting. A big enough leak and you won't get any gas.
A quick check to confirm would be to run the generator off a gas can on the ground next to the generator. The fuel pump can draw from a can as long as height difference isn't too great.
Jan-10-2014 07:13 AM
Jan-09-2014 08:38 PM
Jan-09-2014 08:28 PM
JimM68 wrote:
I haven't read the history (other related threads), but the only relation between the genny and the shore power is the transfer switch.
If everything is 100% OK on shore power, then your genny isn't doing what it should, or your transfer switch is screwed up.
As I din't read any of your other threads, is your rig 30 or 50 amp?
What kind of power management system does it have?
Exactly what genny?
Jan-09-2014 05:39 PM
Jan-09-2014 04:16 PM
Exactly what genny?
Jan-09-2014 02:12 PM
krinderhagen wrote:1995brave wrote:
Listening to the video, here is a question. Have you replaced the gas cap on the RV recently? Weather you have or have not, remove the gas cap and run the generator again, let us know if it runs longer or not.
ok i will be right back with the results of that
Thank you
Jan-09-2014 12:23 PM
Jan-09-2014 12:15 PM
Jan-09-2014 10:52 AM
Exactly what genny?
Jan-09-2014 10:07 AM
Jan-09-2014 09:58 AM
