Air pressure alarm
Upstate
1994 newmar pressure alarm going off while going down road
6 REPLIES 6
BTPO1
I don't have air brakes, but is it possible that you have moisture in your air lines that is freezing? Just thinking.
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
path1
Freezing weather it started doing it in?
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
fcooper
It could also be the air pressure sensor. I don't know where it would be located on the newmar. A lot of the monaco coaches have it just below the parking brake pull actuator. Some freightliner chassis have it along the rear frame rail driver side.
Fred
Fred & Vicki
St. Augustine, Florida
Upstate
Pressure is good on gauge. I drained air tanks.
wolfe10
Could be something as simple as the governor that controls the compressor or a massive leak.
Do NOT attempt to drive until this is resolved. As I am sure you are aware, if PSI drops below 30, the emergency/parking brake WILL deploy.
First step is to listen for a leak. If that is not it, replace the governor-- should not be over $25.
Sure, it could be something more expensive, but start with the cheap and easy.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Tom_Barb
What does the pressure gauge read? Do you have a major leak or a compressor failure?
