Aladdin Momitoring System
tonywish
I have a 2005 Signature and on my Aladdin System when driving the unit is on then after about ten minutes goes blank like it lost a video feed. The green light on the monitor is on but no video feed. When I stop and turn the engine off and on like at a fuel stop it again starts up and then goes off. I put it in the garage and turned it on without the engine and it stays on. Any suggestions??
Tony
2 REPLIES 2
Executive45
Tony,
Check the cabling at the back of the unit. It sounds like one of the cables is loose. There should be four cables attached. One for the backup camera and three alternates...mirror cameras, inside camera etc. If one is loose, the movement of the coach will not allow a good connection. When stopped, it does. Find the 'brain' and make sure all cables are pressed in tight. If it's happening on both the front display as well as the one in the bedroom, then it's probably wiring at the 'brain', otherwise it's probably the wiring to the front display.
I found it a good idea to get a package of zip ties from Home Depot and zip tie all my wiring about every 8-12" throughout the coach. This prevents this type of incident. Loose or hanging wires are simply wires waiting to fail....good luck, hope this helps...Dennis
Twomed
Monaco Info
Welcome to the forum. 🙂
Suggest you post your question on the link above. Also if you do a search there an Aladdin Manual is available to download.
Happy Trails 🙂
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
