โOct-13-2013 10:14 AM
โOct-14-2013 08:31 AM
โOct-13-2013 02:50 PM
YC 1 wrote:
Doug is trying to tell you something in his post.
IF plugged into shoreline and the engine is running this is a common/normal event.
Under certain circumstances the generator can cause the same symptoms.
Even strong solar panels can cause the system to alarm but is much more rare.
In any case the first thing is to put a voltmeter across the batteries to see what the voltage is running.
โOct-13-2013 02:47 PM
dougrainer wrote:oly1946 wrote:
no the alternater is not showing a charge,the mechanic says it is in the starter relay what and where is the relay you are talking about
The Starter relay?????? Find another mechanic. It is NOT the starter relay. 2 things only. 1. The Alternator is bad or the Voltage Regulator. 2. Some Alternators have the voltage regulator built in. Not sure about Monaco Roadmaster Chassis which is which. Doug
โOct-13-2013 02:27 PM
โOct-13-2013 01:06 PM
โOct-13-2013 12:04 PM
โOct-13-2013 12:00 PM
โOct-13-2013 11:04 AM
โOct-13-2013 10:29 AM
oly1946 wrote:
I have a Monaco Camelot 40ft motorhome the alternater light will not
go out, I have put new one on the light still stays on also new batterys
