Another paint checking question - Round 2
LongWeekends
I appreciate all your info and feedback on paint checking on my other thread. I now know what causes it, etc...that isn't my question here.
If paint checking(albeit VERY minor) is present, will it continue to spread even if the coach is stored out of the sun going forward? Or will it stay like it is and not get any worse if the coach is always stored under cover?
Michael
Just me, my wife, our daughter and our two big, hairy Goldens.
6 REPLIES 6
LongWeekends
ncrowley wrote:
It will get worse. I purchased a coach with paint checking and thought if I kept it under cover, it would not get worse. I was wrong. Within 2 years, the checking in the dark spots (where the worst checking was) got so bad that it lifted off the clear coat in a number of areas. At that point, you have a problem. And I kept the coach totally out of the sun whenever I was not using it. If it is in the sun, I assume it get worse more quickly, but no matter what you do, it will get worse.
Thank you, that is the info I was looking for.
Michael
ncrowley
Wax may help but it did not stop the checking from getting worse. I waxed the coach at least 4 times per year and the checking still got worse.
Nancy
Newmar Northern Star
RayChez
Apply a good wax and it will help.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
ncrowley
Nancy
s_N_s
As already stated, it will continue. At what pace will be determined as to how much exposure it gets to the elements.
Steve & Sally
Hudson (Our Little Pom)
HiTee, Houston & Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 pt Cruiser Vert 5 speed
Demco baseplate with Commander Tow Bar
"Never try to outsmart your common sense"
imgoin4it
It will continue to get worse. Just how fast it gets worst, I believe, depends on the color and how much it is exposed. Darker colors of course get hotter and checking occures at a faster rate.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
