antenna
bsjones11
Just got to a campground with no cable and using antenna. Worked fine when last used but this time only 2-3 channels. Have checked all connections and hooked directly to tv but still only 2 channels. Can an antenna just go bad?
Did all the normal set up. Amp is on and did the channel scan.
9 REPLIES 9
Goldencrazy
I'm not sure what wired direct means but it certainly means no amp unless you used coax from the amp. I have a Jack and it can change dramatically. With digital you either have the channel or not. I liked the old way when you got a channel even if it was a bit fuzzy.
fourmat
amplifiers can go bad mine did worked fine 2 weeks later No good replaced antenna head all was fine
2009 Challenger
mccsix
Watch the weather it has the biggest impact on over the air signals in marginal areas.
Dale_Traveling
Presuming a batwing or similar RV type antenna other than a round omni directional type, rotate it 90 degrees either direction and rescan. You may need to do this at 180 and 270 degrees from the crank up position. The antennas are somewhat direction and even thru you could be at the same camp ground where the system work fine last week a different camp site may have the coach pointed in a different direction which can effect performance.
2006 Hurricane 31D built on a 2006 Ford F53
rgatijnet1
If you connected the antenna directly to the TV you just took the antenna amplifier out of the circuit. Make sure that the amplifier has power and then go back through the set-up procedure with the antenna hooked up through the amplifier.
Old-Biscuit
Did you get MORE channels at this same CG or was the more channels at another location :H
Everytime you move/set up you have to:
turn antenna booster ON
crank antenna UP
AIM antenna head towards TV towers
Set TV input to 'air' (antenna) vs cable
then scan for channels
Have to do this even if you come back to same place.
tropical36
Recently at a wooded campground in NJ, we were only able to receive one channel, but had plenty to choose from the previous day at a Walmart, only about 10mi away. H...., we were able to do one in Glacier National Park some years ago, so..........
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
BB_TX
Did you select "air" before you did the scan?
edbehnke
sure it can. but, check with your neighbor to see if that is typical for that area. I've been to places where you can't even get stations.
I assume you did the scan for the tv channels.
eddie and sandie
3402 Montana 2013
Ford F350 2015
