โJun-17-2017 10:30 AM
โJan-19-2022 12:12 PM
โJan-15-2022 07:10 PM
nohurry wrote:
That came out good. You may still have to put slats, or rods etc at the front of the shelves. Otherwise the contents will end up on the floor when you open one of doors.
โJan-15-2022 07:34 AM
โJan-14-2022 06:51 PM
โJan-14-2022 06:45 PM
โJan-14-2022 06:43 PM
โJan-14-2022 06:39 PM
โJan-14-2022 06:37 PM
โJan-12-2022 07:00 PM
โJan-11-2022 06:58 PM
โJan-10-2022 07:02 PM
โJan-10-2022 06:59 PM
โJan-10-2022 06:57 PM
โJan-10-2022 06:56 PM
โJan-10-2022 05:51 PM
Old Islander wrote:
I had to make a bunch of frames similar to that and found a half-lap joint to work well. If you set up your table saw, you can cut a bunch of them very quickly, in one operation. Run the piece through a number of times, nibbling away the material so the depth and length of the lap are the same on each. A bandsaw works too but requires two set-ups. Assembly with glue and a couple of small brads, and the wood will bust before the joint.
