โJun-17-2017 10:30 AM
โDec-27-2021 06:15 PM
โDec-27-2021 06:09 PM
Benizel wrote:
Every time I do some DIY projects around the house, I always like to get as creative as possible. One of my favorite materials is wood.
โDec-27-2021 05:51 PM
Bruce Brown wrote:fulltimin wrote:Bruce Brown wrote:Wanderlost wrote:
Toilet looks like it could use a bit of maintenance (and cleanup)...
On a serious note, a can of Krylon Fusion and this thing would look presentable again.
What color would you like?
Not my circus, not my monkeys.
LouLawrence wrote:
On a more serious note, throw out the trash and get the wife a nicer place to take care of some private time.
โDec-27-2021 05:50 PM
My favorite color of course, Bright Green. Seriously, I would not worry about it until I was almost finished with the build and then consider if it was worth rebuilding or just replace it. If replacing, I would go with a Porcelain Bowl.
โDec-27-2021 04:30 AM
โDec-24-2021 04:26 AM
โDec-24-2021 04:04 AM
โDec-24-2021 02:53 AM
โDec-23-2021 07:04 PM
โDec-23-2021 12:26 PM
โDec-22-2021 06:39 PM
sundancer268 wrote:
I love the thinking outside the box. As long as it finishes in the next ten years or so, I will be happy.
โDec-22-2021 06:38 PM
LouLawrence wrote:
It seems the OP works harder at finding absurd uses of wood than working toward completion. It gets more and more bizarre as the thread gets longer and longer in tooth. I'm still hooked but I can't for the life of me figure out why!
โDec-22-2021 06:35 PM
PastorCharlie wrote:
I use all the hollow spaces in my tires to store air.... counting the spare, I have 700 lbs. stored away in case a need arises. ๐
โDec-22-2021 06:34 PM
navegator wrote:
I used two bread boxes turned upside down on the tiny head above the door and the loo, with rv overhead springs, wife used them for everything that she needed, finding small spaces in an rv is a chalenge, I found other spaces behind the speakers in the cabin, under the couch, the pilot and copilot seats and the "shower/tub" for that space I had to cut tbe side and instal a door outside, that is where all the potable water conectors, hoses, preshure regulator, etc. recided.
As you go along you will come up with more nooks and cranies to use.
navegator
