โJan-25-2014 05:15 AM
โFeb-02-2014 05:48 AM
bob_nestor wrote:
Sharp makes a combination microwave/convection oven (RS820 I think) that is virtually the same size as the Apollo used in the Class B's. They even made a mounting kit at one time that routed the venting out the front just like the Apollo. These Sharp units are widely available at places like Walmart and they're pretty inexpensive. Unfortunately Sharp seems to have stopped production on the mounting kits. There are still some available, but it's a real treasure hunt to find one nowadays.
โFeb-02-2014 05:31 AM
โFeb-02-2014 05:15 AM
โFeb-01-2014 06:11 PM
erip wrote:
I have a 2007 holiday rambler augusta sport. My apollo microwave went last year as well. I replaced the microwave with one that fit the space but the feet weren't in the same spot so i moved the the plastic brackets.. then added L brackets at the cabinet edge.. the microwave still bounces around quite a bit . i haven't figured out a wave to keep it really secure.. glad to hear that others have had the same issue and solved the problem better than I
โFeb-01-2014 05:53 PM
โFeb-01-2014 07:12 AM
BennieH wrote:
Ours died last fall on our last trip for the year. This is what I did:
Once home I found that the control board broke loose (very crummy mounting method! Surprised it lasted as long as it did) and cut the Keypad ribbon cable. Called to get just the keypad ($32). Since they changed the parts a few years ago(of course) the parts would be $140 for everything needed instead of $32 and an entire new unit is $499!
I took the whole thing apart & I found that you can remove the micro/convection part from the housing. There are only 4 screws holding it in the housing and about 12 holding the housing cover on. Once removed, I found a Magic Chef 1000 watt Microwave only unit (we never used the convection part) at my local Menard's for $79 that fit in the housing perfectly. We then still have a Microwave and the vent hood. Also there is plenty of airspace around the microwave for cooling.
A little over 2 hours work and $79 we are are fixed up again!
โFeb-01-2014 04:20 AM
โJan-26-2014 09:40 AM
JTCHess wrote:
Great comments, thank you. I'll be heading off to Best Buy today.
โJan-26-2014 04:50 AM
โJan-26-2014 01:26 AM
โJan-25-2014 05:48 PM
โJan-25-2014 12:41 PM
โJan-25-2014 09:57 AM
โJan-25-2014 09:32 AM
