Aqua Hot Questions...
sloman2001
for a MH "wanna be".
We are considering a coach with the Aqua Hot system (I have read the operating manual) and are trying to find out a little more about it, so thank you in advance for any responses. Without laying out a litany of questions, here are 5 questions about the Aqua Hot system Iโ€™m seeking clarification on.
Can you use the AH hot water system when camping in sub 32 degree conditions (maybe 25 degrees), or must you always winterize if it is going to get below freezing? We often camp in colder weather, so I just want to know if I need to winterize at the slightest chance of 32 and below. (not asking about the coach heating, but the water heating system)
Generally, what constitutes the bay heating system (maybe coach specific)? Do I need to ask the particular dealer?
To winterize, I have read you cannot merely blow out the lines, but you must use anti-freeze. I am just curious as to why?
If you are going to be driving through conditions below 32 degreeโ€™s and are using the engine to heat the rig, do you still need to winterize your lines?
For heating only (not for the continuous water supply) to what general outside temperature will Aqua Hotโ€™s use of the 120 VAC burner be sufficient before the diesel burner kicks in or will electric alone provide enough heat? In reading the operating instructions, it sounds like the electric element alone will heat the anti-freeze solution for heating. But it also sounds like you need the diesel burner, so I am just a little confused. Any clarification here would be helpful.
Maybe these sound a little dumb, so thanks for your patience. Thanks again for your time!
Tom
15 REPLIES 15
wny_pat1
Two places for everything you want to know about Aqua-Hot -
http://forum.rvhydronicheaterrepair.com/forum.php
any (you will have to join Yahoo Groups for this one - http://groups.yahoo.com/neo/groups/HydronicRVHeating/info
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
