atwood G6A-8E water heater leaking at cold fitting
gregdcwirth
The dripping has been progressing, and I finally crawled underneath. The cold water fitting at the tank seems to be leaking. When I closed the bypass valve to release water pressure, the leak stopped. It only leaks when under pressure. I checked the hose connection to the brass fitting, and it is tight. I wonder if there is a leak in the tank, but wouldn't it leak, pressure or not if there is water in the tank?
I am stymied, and would appreciate any ideas.
The unit is old, and I will replace it if I need to, but is there some inlet repair I could do??
Thanks, all.
6 REPLIES 6
Gjac
I am not sure what kind of end fitting you have and how it is suppose to seal but if it is not a flare or bubble end maybe some Teflon tape would seal it. I would remove it and see.
gregdcwirth
Oh, and the pressure release valve seems fine. It is at the front of the unit, and there is no moisture around the pressure release valve where it screws into the heater... Can it leak behind the front panel?
gregdcwirth
Thanks for all your suggestions.
My tank has a metal nipple. A brass fitting attaches to that and a brass female end attaches to that. The hose is plastic and is crimped to the brass female end. Very old school.
The crimp is solid, the female is tight to the brass elbow fitting, and that's as far as I've gotten with my exploration. The cardboard and insulation around the tank was all wet, and I couldn't really assess the metal nipple at the tank. Lots of calcium type buildup around that nipple as well. I will do more exploring tomorrow. It's a very tight squeeze under the coach, with little wiggle room to play with tools....
stickdog
I had a cracked plex fiting that attched to the nipple from the tank.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
Artum_Snowbird
Many a leak can start from the pressure release valve too. It's only a ten dollar fix and might be worth it for an easy fix. It could leak all the way down to the inlet inside the insulation.
Is it an electric/gas model?
Put a paper towel around the fitting where you suspect it is coming from, and put the pressure to it for just a short time. You will notice the wetness on the towel before you will see the drips if it is coming from there.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
enblethen
It could be the threaded fitting going into the tank. Some rigs have a plastic nipple and some have a plastic check valve.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
