Awning issue
outboardfever
Has anyone had a electric awning that will not extend? Mine will unroll but not extend unless you pull on the arm.
8 REPLIES 8
Mile_High
On our carefree on our fifthwheel, if the awning slid down the tube just a bit (wind), it would roll up with the arms not truly square and they would stick when trying to unroll to the point I had to tug on the arm. I just wrestled that awning and tube to realign it. It only took a fraction of an inch.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
crasster
Typically they just extend out. What is it getting stuck on? Is there any parts that need some wd-40?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
dougrainer
Yes, I have had that happen. I fixed it. Doug
Winnebago_Bob
Does it have pneumatic helper arms (gas shocks)? If so, that could be it.
2017 Winnebago Aspect 27K
PastorCharlie
The motor end bushing is exposed to the weather and sometimes it will rust from inaction....Need to be lubed with Blaster if that is the case.
CA_Traveler
Mine was similar and the issue was the Monaco and CareLess wiring. Of course there can be other issues.
What model awning, rig, etc?
2014 Grand Cherokee Overland
Bob
wrgrs50s
Just a thought but is your battery fully charged?
Next maybe your arms are binding up. Try some silicone lubricant and see if it helps.
Motor just may be going bad !!! Expensive !
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
2oldman
I think gravity does the extending. Is your coach upside down?
