โFeb-25-2002 07:07 PM
โJul-05-2021 02:00 PM
โJul-01-2021 03:44 PM
โJun-27-2021 07:29 PM
bobndot wrote:
Hi Dale, this is probably a common blocked canister where the vent hose becomes clogged as well. It should be a simple fix by your mechanic.
Its EPA ORVR - 'Onboard Refueling Vapor Recovery' related , as you pump gasoline into your gas tank it pushes out air thru a vent tube canister filter setup. When the air can't escape due to a clogged line then the nozzle at the fuel pump shuts off.
Those nozzles are highly intelligent, I don't how they know when those canisters are clogged but they do. ๐
โJun-27-2021 07:25 PM
IAMICHABOD wrote:
I,like you sometimes have a problem with filling my tank on my Express Chevy based Class C, Everything else checks out OK but I have found that if I hold the nozzle at a 45 degree toward the rear of the Motorhome I have no problems. It seems that small filler tube doesn't vent well and holding that way lets the vapor recovery work.
I also have the same problem on my GMC Yukon the trick also works on it too.
โJun-27-2021 07:16 PM
โJun-27-2021 06:47 PM
โJul-15-2020 08:26 PM
โJul-15-2020 03:36 PM
โJul-15-2020 03:24 PM
Orion_42 wrote:
Sounds all good. Did you, or are you, going to tow the Miata? Iโm pondering a toad to pull behind my M211.
โJul-15-2020 03:09 PM
โJul-15-2020 03:01 PM
โMay-28-2020 07:14 AM
โMay-28-2020 05:34 AM
โJun-15-2019 03:19 AM
