Banging when turning
country_sunflow
Have a banging noise under the motorhome, it is a 2009 Fleetwood discovery
Anybody have any ideas as to what is wrong. Nothing in the basement is moving around. DH thinks it is an add-on stabler bar, anybody please help. Would like to leave on a winter trip soon. MH only has 15,000 miles.
13 REPLIES 13
MrLugs
Take a look at your drive shaft center hanger bearing while your down there.
2000 Southwind Storm 30H 31.5'
Banks Powerpack system
2003 Jeep Rubicon Toad
and a Dog
country_sunflow
Thanks for the suggestions, will check it out tomorrow. Thanks again
country_sunflow
Thanks for the suggestions, will check it out tomorrow. Thanks again.
hanko
I wouldnt do any banging when driving
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
B_B
If the front end was aligned, I would check the tie rod adjusters, they may be turned where they hit something.
wolfe10
Yup, check the sway bar end link bushings and shocks/shock mounts.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Carvin_Marvin
Broken upper shock mount, perhaps
Gjac
Loose shock mounts maybe. Is the noise only when sharp turns at low speeds or slight turns at high speeds? Does your MH have Steer safe added to the front?
country_sunflow
We will check the bearings. Thanks
roam1
did you add a stiffer anti-sway bar?
maybe the bushings are causing it
country_sunflow
Forgot to say that it sounds like it is coming behind the front tires.
country_sunflow
Turning either direction. No work done except had it lined up last spring.
Trackrig
I have a 2005 Excursion, almost the same thing. I have no idea as to what's causing it, but I'd like to know.
Does it have when going slow like in a parking lot or fast?
All turns or just sharp turns?
Turning to the right side or left side, or both directions?
Is the noise in the front or rear of MH?
Is it on the left or right side?
Any recent work or changes done to the MH?
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
