basement heater
gonefishin77
Looking at this unit HEATER
Contacted Monaco about getting all the factory components and not sure I need to spend that much money right now. I have the wiring from the inside control panel down to the water bay and think it would be a good replacement for the factory one from Monaco.
What are your thoughts
5 REPLIES 5
conmoto
Looks good for replacing the 12 volt heater you have now.
jauguston
That is a 12v heater. Is your failed heater 12v or is it a 120v AC heater? If you need a 120v heater Walmart has several that are quite inexpensive or as someone suggested use a low watt light bulb. I use a 25w light bulb in my water compartment when winter stored.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Clay_L
You might want to check on the wire gauge going to the compartment. A quick check indicates that if the wire is about 15 feet long (just a guess on length) it will need to be 6 gauge to have an acceptable voltage drop (3 percent).
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Ivylog
Unless you are hooked to shore power or going down the road, that 12V heater is going to kill your batteries really fast. Many use a 100 watt light bulb even putting it on a Tstat.
Upgraded with a 08 HR Navigator 45’...
Passin_Thru
Go for it.
