Battery Compartment
zach477
I just got two new batteries, and I want to make maintenance as hassle free as possible. They're stored under the stairs, and you have to removed two screws access the batteries. I know it's not really THAT hard, but still...
Anyone done any mods to make it easier? Maybe some kind of latch or something? Something I wont' stub my toes on...
6 REPLIES 6
FIRE_UP
A hint here. If you decide to go with Velcro, don't use the cheap stuff. Use what's called "Dual Lock". There are not two different sides, as in normal Velcro. Most, if not all, Velcro has a soft fuzzy side and, a plastic side. But, the Scotch lock has TWO plastic sides. When they lock, THEY LOCK! But, you can still lift on the cover and they'll separate. And, that kind will NEVER wear out, like normal Velcro will.
Scott
Dual lock Velcro
Scott and Karla
SDFD RETIRED
KI60ND
zach477
dons2346 wrote:
Velcro
Winner!
Can't believe I didn't think if this. I use Velcro all the time. 🙂
DrewE
My Coachmen uses a draw latch that is very similar to one of these for the battery cover/entrance step. Other sorts of draw latches would probably be just as effective, and many are pretty low-profile.
dons2346
Velcro
Vulcan_Rider
gbopp wrote:
Maybe someone will have a better idea.
Too late now but maintenance free AGM's would have solved the problem. As well as not having acid splash around to corrode things.
gbopp
Wow! 2 screws. You're as lazy as me. 🙂
I've never done it but, how about small powerful magnets? You can buy them on Ebay.
Epoxy will hold them in place.
