Battery door on 2005 georgie boy pursuit
tom68
This might be a dumb question.
Had the motorhome for a few days can't figure out how to open the battery door.
It's in the front of coach. Thanks
9 REPLIES 9
tom68
tmarie416 wrote:
We have a 2004 Georgie Boy, we need a key. You can buy them at Camping World or maybe even Amazon. A dealer is more than likely your best bet. Good Luck...
Thanks everyone I got the keys on order
tmarie416
Tina & Greg Cornell
2004 Georgie Boy Pursuit
2007 Chevy HHR
Trinity, FL
mtrumpet
A couple of pictures might help.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
GPWayne
I have the same thing on my rig.
The tabs are held in place by Barrel locks. You need a locksmith to make a set of keys for you. This setup is used on many RVs and has been around for years.
Whoever sold you the MH should give you all the keys!
You use the key to unlock the door and use the tabs to pull the door open.
tom68
DSDP Don wrote:
Are these tabs really barrel locks. Did you get a round key with the coach?
NO. I got no key like that
Thanks any guys. Glad you tried.
DSDP_Don
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
tom68
It's a 2005 georgie boy pursuit.
It has two small hard rubber tabs on both sides of the compartment.
It almost looks like a button in the middle of the tabs but nothing you can push. I think now it's some kind of rivet that holds the tab in place.
The grill is below this compartment. Is there some latch that you stick your fingers in to release like on a car.
RayChez
Need more information in order for somebody to help or give you some information. What brand of coach do you have? Do you need help with the key not unlocking the compartment door? If it is in the front are you referring to the hood of the coach?
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Gjac
What kind of latch is it? Does it have a key and you can't turn it?
