โJan-14-2015 06:34 AM
โJan-15-2015 10:07 AM
โJan-14-2015 11:43 AM
โJan-14-2015 11:30 AM
10forty2 wrote:
Overcharging is the likely culprit, but it can also come from a short circuit.
Your house system is likely 12VDC, so each battery would have to be 6VDC and be wired in series to achieve the 12vdc required. You can power the house with a single 12VDC battery but many prefer the extra amperage you get by having 2 6VDC batteries.
โJan-14-2015 09:23 AM
โJan-14-2015 09:13 AM
Dakota98 wrote:
Battery FAQ
What causes a swollen battery ?
Immediately remove the battery from the device. A battery becomes swollen as a result of overcharging.
Excessive current will flow into the battery after the battery has reached a full charge.
The constant current will cause decomposition of the water in the electrolyte and premature aging.
At high rates of overcharge a battery will progressively heat up. As it gets hotter it will accept more current, heating up even further.
This is called thermal runaway and it can destroy a battery in as little as a few hours. The heat will cause the battery to expand.
โJan-14-2015 08:42 AM
โJan-14-2015 08:01 AM
โJan-14-2015 07:34 AM
โJan-14-2015 07:30 AM
โJan-14-2015 06:45 AM
