Bedroom slide creeps out after setting a while.
mlbdp
Driver side bedroom electric slide creeps out after setting a while. What's the fix?
2006 Beaver Monterey 38
Roadmaster, 400 Cat C9
2009 Saturn Vue
GS, FMCA 305555, SKP 104572
USN RETIRED
10 REPLIES 10
dougrainer
Click this link to show the standard PG motor and brake. That lever is sometime hidden by the black vinyl end cover. Doug
http://rvcomponents.visonerv.com/cgi-bin/md/M2078/s1.pl?
Disneyfix
10forty2 wrote:
dougrainer wrote:
With NO info(brand/ make of RV or slide system), the simple answer is the electric brake on the motor release lever is off. Doug
My slide was slightly extending even though it was "reeled" all the way in. Turns out, it was EXACTLY what Doug said here. The brake lever had gotten flipped from stuff stored and moving around in that basement compartment and it wasn't holding. Flipped it back and all was good.
Any pics of that or describe further. I have never seen a brake in my basement...maybe there haven't seen it. Thank you.
dougrainer
Ivylog wrote:
They are all electric... a 12V electric motor driving gears or hydraulic pump. My hydraulic BR slide did it after a day or two so I would bump the close switch once a day. This fixed itself,
Don't be a smart ***. They are either Electric or Hydraulic or Cable driven. Doug
Ivylog
Upgraded with a 08 HR Navigator 45โ€™...
dougrainer
smlranger wrote:
If it is the HWH system with hydraulic slides, you may have a weak solenoid. A weak 'Extend' solenoid will let the slide creep out. I had a creeping out slide and just had the extend solenoid replaced. Fixed it.
He stated it was an Electric slide. Doug
smlranger
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
10forty2
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
wallynm
We always use slide locks. You can make them out of 4 bys by cutting and fitting between the slide and the wall when the slide is in. If you want you can pad each end to prevent scratching the wall.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Johno02
Slide locks.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
dougrainer
