Best oil for 460 with 11k
cm2785
Hi guys my 96 Bounder 34j F53 has the 460. The rig has 11k. What do you guys think the best oil is? I’m hearing Rotella for the zinc but it’s not in 5w30. Any advice is greatly appreciated!
17 REPLIES 17
John_Joey
I used Rotella 15w40 in mine teamed up with a K&N oil filter. Drove it all over the country with never a problem. As I remember you want to use Rotella because the 460 was a flat tappet engine.
Possible future SIL bought a newer but used F150. To lazy to change oil so he switched to syn from Dino to reduce oil change frequency. Engine blew, and the mechanic said it happens all the time with Fords. Ok to change to syn, but you have to change it just as often as Dino. So what's the point of spending the extra money unless you're always running hot.
MH's don't get that many miles on them per year. With my Class A 460 I figured Rotella twice a year, worked for me with zero problems.
There’s no fool, like an old fool.
WILDEBILL308
You are right about the "Oil viscosity has little to do with oil QUALITY"
Well I think the 0-30 Mobil one will exceed all the API Ratings.
Mobil 1 0W-30 meets or exceeds the requirements of, ACEA, A1/B1, API,SN,SM,SL,SJ, ILSAC, GF-5, Ford, WSS-M2C946-A, Ford, WSS-M2C929-A
Mobil one has a new european standard that is 0-40 weight that might be better in the hotter mounths.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
theoldwizard1
WILDEBILL308 wrote:
I just wonder why people buy an expensive investment and run the cheapest oil they can find not the best oil they can find.
I ran the 0-30 in my 460 when I had it.
Bill
Oil viscosity has little to do with oil QUALITY. API ratings tell the story. 0W30 would improve very cold starts.
Walmart brand oil (SuperTech) 5W30 and 10W30 meet API SN standards.
theoldwizard1
T18skyguy wrote:
I saw a demonstration once of two engine oils tested against each other. The test rig simulated oil passages all the way up to the cam, and was made of glass. One oil was straight 30 weight and the other 10-30. The 10-30 always got to the cam much faster than the 30 weight, but the interesting part is it remained true even in 90 degree temps not just cold temps. The lesson being always use a multi-vis oil.
I don't think I have seen a single viscosity oil that meets even 20 year old API standards. (Current is SN. 20 years ago it was SH.)
WILDEBILL308
Bill
450 HP CUMMINS ISM
-Mark Twain
T18skyguy
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
theoldwizard1
Old-Biscuit wrote:
Any oil that meets/exceeds mfgs recommendations and change it regularly
Concur ! Mobil 1 is good, but there are a many other less expensive good oils, including Motorcraft synthetic blend. Even Walmart brand would be acceptable.
ksg5000
I use Walmart House brand synthetic in 460 rig, audi, and volvo .. they don't mfg the weight required by my new Honda so I will have to choose another brand when it comes time to change that oil. I spent many years in Private Label business and I have no problem buying house brands.
Kevin
gutfelt
azdryheat wrote:
The best oil is the one recommended for your engine and cahnged regularly. There is no magical best oil. I've never found one oil to be better than an other and have never heard of any oil causing an engine failure. What ever weight oil that is recommended for your engine is what I'd use. Dino or Synthetic is your choice. Just change it regularly. I wouldn't run diesel oil in a gas engine but that's just me. There's plenty of oils to choose from and they're all good.
ran 15/40 (diesel oil)in many many engines over many miles in the old days
now days the hot running more hitech engines all seem to want 5-20 or 5-30
azdryheat
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
the_silverback
X2 on Mobil 1.
the silverback
2015 crossroads Rushmore 5th wheel
RLS7201
I use Walmart Syntec 10W30 in my 95 F53 460. Pulled engine at 120,000 miles to add a stroker crank. Cylinder walls, bearings, cam & lifters looked good for another 120,000 miles.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
T18skyguy
My 96 460 called for 10-30. Your in So-cal so that should fit the bill well unless you intend to go to very cold temps, in which case do the 5-30. Mobil synthetic good stuff.
Dutch_12078
I used Mobil 1 High Mileage formula when we had a 460. It has a higher zinc level than the others. Only 11,000 miles on '96? That thing has sure been sitting around! 😉
Dutch
2001 GBM Landau 34' Class A
