I wouldn't use a stinky slinky on a bet. The macerator is so much cleaner and easier. That said, I've been using a macerator on my last two coaches. Here's what I do, YMMV.
1. I close the grey water valve before we shower in the morning.
2. I then pull the black handle, run the pump and let it do it's thing.
3. When done I leave the black tank open and open the grey valve for 30-45 seconds, then close just the grey valve.
4. I turn the pump on again and let it finish emptying the black tank.
5. Repeat #3 and #4 above.
6. Repeat #3, but this time close the black valve after 30-45 seconds.
7. Run the pump to finish emptying the grey tank.
This method uses the hot shower water to flush and clean the black tank completely. It also leaves a base of soapy water in the black tank from your shower. The final run of the pump runs the final shower water through the pump and hose leaving them clean.
We are in our fifth year of full timing and never have had a problem with the black tank or the grey...Dennis
We can do more than we think we can, but most do less than we think we doDennis and Debi Fourteen Years Full Timing
