Blowout!
Monkeyman_and_L
Waiting on roadside assistance. Passenger side tow dolly tire blowout. We were making good time too.
Thing is, I didn't see anything on the camera that indicated a problem and the RV was pulling just fine.
Guess who's getting more tpms sensors for the toad rig!
Could have been worse.
Monkeyman, Lady and little chimp
2018 Newmar Baystar 3414
2022 Ford Escape Hybrid TOAD
13 REPLIES 13
Monkeyman_and_L
CapriRacer wrote:
A couple of thoughts:
First, it is possible that this was just a road hazard - it happens.
Second, what tire size is it? As was mentioned, LT tires do not come in 12"! Why is it that some people immediately assume that you can replace any ST tire with an LT?
Third, How did you get home? Replace the tire? Got it patched?
ACME says that towing at posted highway speeds hasn't caused any issues, so they're thinking road debris. And it's entirely possible that's all it was, since the tire was shredded by the time I got a look at it, I will never know.
Tire size ST145R12. I don't expect I can replace this with anything else. The LoadStar tire is 10 ply rated E, so it's good stuff, again pointing to a road debris failure.
Called recently acquired Good Sam roadside to get the tire replaced with a spare I bought. Now I need to replace the spare. Thinking I'll get 2 as they're small enough and inexpensive enough to keep in the underbays.
CapriRacer
CapriRacer
Visit my web site: www.BarrysTireTech.com
hipower
Monkeyman_and_Lady wrote:
Just bought the dolly this year. Date code on tire is 2017. They are indeed ST tires.
Do they make LT tires in the 12 inch range?
I guess I'm never too old to learn something new. In a previous post you mentioned tire pressure being 75 psi and I thought that seemed high from my experience. Then in this post you refer to 12 inch tires which also surprised me, but makes more sense out of the higher pressure.
I've don't recall ever seeing a tow dolly with 12 inch tires. The one we towed for many years had ST205/75-14's as stock and were replaced with similar tires as needed. If memory serves, we got 5-7 years out of them.
Monkeyman_and_L
BTW, got home okay, but kept speed at 65 as best I could.
Monkeyman_and_L
Mile_High
If those are ST tires, see if you can dump them for LTs, or just replace them every 3 years. In a tow dolly arrangement, the tow dolly tires are the weakest link of the whole rig and limits you to 65 max as stated above (if they are STs).
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Blaster_Man
Dutch_12078 wrote:
...Most blowouts are caused by under inflation according to the NHTSAs...
Yes, and old tires. Sometimes speeding can be a cause. Most ST tires are speed rated to 65.
2014 American Eagle
Bruce_Brown
Moderator
Moderator
How old are the tires? Trailer tires seem to age faster than MH tires.
From an article in Trailer Life ;
"Carlisle Tire estimates that one-third of a tire’s strength is gone in approximately 3 years. Carlisle says to consider replacement after 3 years, regardless of tread depth remaining; and at 5 years definitely replace. That’s just one company’s recommendation.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Monkeyman_and_L
I did check the tires before departure. 75 psi, max inflation says 80. Could have been road debris.
We got fixed up and the spousal unit suggested that we camp sooner rather than later. Since we were doing a 2 day return trip just means more miles tomorrow.
Gonna nurse these tires.
Will look into upgrading the tires to D. Did that on our old trailer. Liked those tires very much.
Dutch_12078
Most blowouts are caused by under inflation according to the NHTSA, something that TPMS sensors are very good at reporting. There's nothing though, that can warn of an almost instant blowout caused by a sharp piece of road debris.
Dutch
2001 GBM Landau 34' Class A
emiddleb
Had same thing happen to me 2 years ago. If it helps, I had TPMS sensors on the dolly, barely gave me about 3 seconds warning when the tire blew. They will help on the slow leaks but not the big bangs.
When replacing both last year, I also went up a load rating on the replacements from my OEM "C" tires that came on my dolly to "D". Gives me a bit of comfort with the 2 extra plys and higher weight capacity.
2004 Winnebago Vectra 40KD
Roadmaster Tow Dolly
I put new tires on our dolly last year as the old ones were showing some sidewall cracking. And I keep it inside when not in use....cheap insurance and since I bought tires already mounted I now have 2 spares.
MrWizard
Moderator
Moderator
glad there is no other damage
yeah could have been lots worse
I can explain it to you.
1997 F53 Bounder 36s
