โMay-31-2018 09:33 AM
โJun-11-2018 08:36 PM
10forty2 wrote:
If you haven't already, replace your sway bar bushings. On my 1999 when I first got it a few years ago, I had pretty bad body roll, or sway. I checked on the bushings and they were deteriorated to the point of basically being gone! Replaced them with poly bushings front and rear, and the majority of sway was gone. Its an hour or so driveway job....not hard at all!
โJun-06-2018 07:50 AM
F4Jock wrote:Then your only option is to add an after market sway bar. Many times it is in addition to the stock sway bar. If you do not have a rear pan hard bar, getting one will make a large difference in handling. Sumos or Timbrens will also help with side to side rocking as they increase the spring rate, and will resist sway.wildmanbaker wrote:
Look underneath at the sway bar ends. If their are 2 holes on each end, move the links to the inside holes. Be sure to check for clearance on the rear SB when raised, to see if it will hit the third member. If it does, longer links will be required.
Unfortunately, my frame was manufactured one year too early for that.
โJun-06-2018 02:20 AM
โJun-05-2018 07:34 PM
โJun-05-2018 05:27 PM
โJun-05-2018 05:10 PM
โMay-31-2018 02:55 PM
โMay-31-2018 12:45 PM
โMay-31-2018 11:16 AM
โMay-31-2018 10:50 AM
โMay-31-2018 10:36 AM
