Bounder 39Z
Jerry__and_Kare
All the labels were removed from my incoming wires leading to my switch panel & VCR & the antenna booster. Guess my first mistake was letting a Mediacom technician into my motorhome! Now the booster boxes for that service have been removed, and I am struggling to get my antenna and VCR reconnected. Any suggestions?
2001 Bounder 39Z
GS, FMCA
2 REPLIES 2
past-MIdirector
You may have to do a continuity check from the antenna by running a cable out the window to the roof antenna lead in. The VCR a continuity check on the cable from the VCR up to the booster to which ever cable has continuity is the one to the booster.
crasster
If it's the matter of running the cable, get a tool called a "fish tape" from Harbor Freight or Home Depot. It should help you run the cable between the wall and whatever else you need to run it through.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
