โNov-30-2013 06:58 AM
โFeb-24-2014 03:18 AM
โFeb-23-2014 11:53 PM
โFeb-23-2014 02:33 PM
โFeb-23-2014 10:44 AM
โFeb-23-2014 08:27 AM
wa8yxm wrote:
There are two different light systems in those handles,
One is a replacable light, the other a hard wired LED,, More on that later
In both cases they are in one of the end brackets, Which one depends on who assembled and wired your rig, Remove a bracket and see if you got lucky.
Now the replacable one... You can get a lamp at either an auto parts store or Radio Shack depending on the lamp.
IF you have the LED type...
LED's should last longer than the rest of the motor home, BUT in order to make it brighter they used a series resistor that is several sizes too small.
Go to Radio Shack
Get a JUMBO, HIGH BRIHTNESS, LED of the color you wish (yes you get a choice)
Get a 450 Ohm resistor (NOTE, 450-500 is fine, You have some wiggle room)
Remove the LED and Reflector assembly
NOTE if the leads on the thing can be easily reversed (Some can, Some can't)
IF they can be easily reversed (The wires that connect to the RV)
Unsolder the existing resistor and LED,
SOlder in the new resistor and LED
Drill the hole in the reflector out so the LED will fit, re-assemble and connect, TEST, if it works, GOOD, if not reverse and try again, Should work now.
Re-assemble handle,, And enjoy
I've done two of 'em so far. (2 different RVs)
โNov-30-2013 07:26 PM
โNov-30-2013 01:28 PM
โNov-30-2013 11:44 AM
โNov-30-2013 09:13 AM
โNov-30-2013 07:48 AM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
