If all you need to do is provide some protection for your valve cores, there are "air through" caps like this
They thread onto your valve stem. The core is not depressed till you push a gauge or air chuck onto the end of the special cap. FYI there are "airless" extensions that work the same way. They don't have to contain air pressure till depressed.
Tire-Man valve stem kits used to come with a set of those caps, and Borg (Dually Valve) did not until perhaps recently. But they're available separately. What look like male threads are rings and they're there to accept the clip-on air chucks shops use when mounting tires. There's no need to put a cap over them.
