Can a converter cause AC problems
gsf35099
Hi Gang, was wondering if DC converter could go bad and cause shorts on the AC side? Pretty sure I have a converter go bad ( no DC power between positive & neutral) and caused my GFCI outlets to get hot & burn.
Thoughts?
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
15 REPLIES 15
Sprig
gsf35099 wrote:
...converter go bad ( no DC power between positive & neutral)...
Proper terminology goes a long way in helping to understand the problem. A DC source is typically measured between positive and ground (or negative), not neutral.
At the moment, since you didn't mention anything other then GCFI going out, I'd consider them two separate issues.
Is the breaker for the 110 for the converter tripped?
