Hard-to-find Bulb
BudFoster37
I have a 2005 Fleetwood Southwind 32V. There are reading lamps above the driver and passenger seats. One of the bulb bases is broken and I cannot find a replacement. The bulb is clearly marked FTD+C 12V 10W. I don't know if this is a coach item or chassis item. Suggestions?
8 REPLIES 8
BudFoster37
I finally found a replacement bulb online. MR16 10w with GU5.3 base.
antsinmypants
look on ebay
FIRE_UP
BudFoster37 wrote:
Thanks for the responses. I'll pursue those options.
Man, if that's true, that you're needing a 10W Halogen, with a G-4 base, that's too bad. I just threw away, about 15 of them, some still in packages 'cause I converted to LEDs all throughout the coach a few years ago. And I replaced all of those high heat, high watt usage bulbs. I couldn't give those things away. Darn.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
BudFoster37
Ivylog
I would suggest replacing with a LED.
Upgraded with a 08 HR Navigator 45โ€™...
JimM68
That is a standard G4 base halogen or xenon lamp.
You can buy them at any home depot, menards, or lowes.
Just make sure the package says 12v 10 watt.
The halogens are often 20 watts.
The 10 watt xenon gives the same amount of light with half the power used.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
enblethen
Most RV stores should have them. some use part number 18-345 or 55-7339
Camco part # 54702, Speedway part # JC10W
10 watt halogen lamps
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dons2346
Look here BULB
Google is your friend.
