CAT 3126 No Start
gfs1943
Due to circumstances beyond my control, I have not started my coach with Cat 3126 for about six months. Went to get it ready for the summer today, but the engine won't start. Batteries are good, starter turns it easily, but no firing at all.
Tank is full of fuel. I tried the manual primer pump, and it feels like the fuel system is fully primed. I drained the fuel/water separator (no water visible, only good-looking fuel). After that, I got about a stroke and a half on the manual primer pump. Really feels like there's plenty of fuel in the system to that point, but it's not getting to the injectors. Any suggestions? Thanks for the help.
BTW, the generator started quickly and ran flawlessly.
gfs1943
USAF, Retired (1962 - 1983)
2006 Monaco Diplomat 40PRQ
2006 Honda CR-V
22 REPLIES 22
gatorcq
Did you check for codes?
Do you see black smoke when you try to start?
Disconnect the IAP sensor, if it starts it will be in limp mode (max 1700RPM)
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
mchero
msmith1199 wrote:
Tom/Barb wrote:
Have some one crank the engine as you crack each injector line at the injector, when you see fuel emitting from the injector line tighten it and move to the next, it will start firing 1 cylinder at a time, when you have enough cylinders firing it will run without the starter's help, continuing bleeding each injector.
Is that sort of looking for a natural gas leak with a match? I realize diesel fuel isn't as explosive as gas, but your method here seems a little risky to me. Not to mention can you even get to the injectors to easily do this while the engine is being cranked?
Read the post, we are talking diesel, not natural gas. Cracking the injector fittings to bleed air is done all the time. If you have a better way please let us know.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Mike_Hohnstein
click
Don't look like any lines to crack here.
Retiredblade
When my Bounder broken down and I was towed to a truck/rv garage in Layfette, La. They had a nice Holiday Rambler diesel pusher there they were working on. I asked what was the problem and the owner said the owner of the rv was sick for six months, couldn't start it every month and it fouled up the injectors and they were replacing them. Could that be your problem? I've ran Cat engines all my working life and NEVER had a engine's fuel system lose prime while sitting, even over the winter. The owner of the garage said it had something to do with the fuel, the sulfur being taken out of it.
msmith1199
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
wallynm
If you have GS-ERS give them a call.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Tom_Barb
Ivylog
Since you have the hand pump... pump it 20+ times and try again. I've been running a machine which will run out of fuel when run on a side slope. It has two tanks and when not that low on fuel it sucks air from the uphill tank. While most will say " NO WAY " I pour gas into the air cleaner, loosen 3 of the 6 injector lines at the injectors and crank it up running on the gas fumes long enough to let me turn the machine to up hill. Tighten the 3 lines and there's still enough gas fumes to crank it again and it usually runs normally as it has an electric fuel pump.
Not sure if you have a grid heater but if all else fails I'd disconnect it and put 3 oz of gas in the air intake and crank it up. Takes a while for the fumes to get through CAC air cooler. Yes I've been called shade tree and I buy starting fluid by the case but in the summer I like gas better.
Upgraded with a 08 HR Navigator 45’...
